Wolverine mods
Old Apr 9, 2003 | 09:52 AM
BigBearFX's Avatar
Default Wolverine mods
what are some good mods that would give a wolverine more low end?[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 10, 2003 | 11:19 AM
superkev's Avatar
I think FST (Four Stroke Tech) had some engine mods for your Wolverine, like a big bore kit, etc.
Old Apr 15, 2003 | 03:42 PM
BigBearFX's Avatar
the fst web site seems to be down and i cant get on it[img]i/expressions/face-icon-small-mad.gif[/img] anyone else having this problem?
Old May 7, 2003 | 09:11 PM
Lucky13's Avatar
[I was thinking of putting a piston and a white brother all around cam or webcam, with a valve spring kit. I already put a e series silencer and whitebrothers powerfilter. Is the piston and cam a worth while mod? I want to go through the powerband stronger. [img]i/expressions/face-icon-small-confused.gif[/img]
Old May 29, 2003 | 01:58 PM
WolvyRider's Avatar
i cant get on the fst website also
Old May 29, 2003 | 02:21 PM
YamahaFlyer's Avatar
I have spoken to several Yamaha mechanics and they recommened a new cam, high compression valves, springs, blah blah blah.... The problem is that with all of this work ($500+ in parts, $500 labor if you have a mech do it for you) you still only end up with a 10% to 15% increase in power. Ultimately the Wolverine's engine is so underpowered that modifying it won't make that much of a difference. They also mentioned, in their opinion and experience, that when you start modifying the engine, your potential for damage is increased greatly due to the increased stress. I have thought long and hard about modifying my engine but I have come to the dissapointing conclusion that for the cost vs. bennefit, I am going to save up for a true Sport quad and get by on my Wolverine for now. I love riding the Wolverine and the autoclutch can't be beat but for really hitting the track and trails with fury and vengence a machine like a Raptor is required.
Old May 29, 2003 | 03:38 PM
Ernie660R's Avatar
Install a good aftermarket exhaust, K&N filter w/outer wear. and a jet kit. Just doing that will wake it up.
A high compression piston and aftermarket valves and springs are good also, but the first suggestion is the better way to go. A lot easier on the pocket book.
Old May 30, 2003 | 12:13 AM
SpDdEmOn's Avatar
A tip that Mickey Dunlap told me and I would trust him is that even if you have a stock motor that just putting in a set of race valve sprigs will help the motor rev up quicker and that really helps. A higher compression piston would help and since you would be tearing the top end off to do that you could go with a smaller overbore. Pipe and jet kit will wake it up along with an intake kit. Mickey can tell you all the ends and outs on it and is very helpful.
Customer Service #1
May 15, 2020 08:46 AM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
