helpppp my banshee wont idle, what to do??
Old Apr 25, 2000 | 09:26 PM
blake350's Avatar
i have a banshee and it just got a topend job done on it, they called me today and tell me it wont idle they messed with it for an hour and cant egt it to idle, whats the problem, they cleaned my carbs and everything and still wont idle, what do i do???
Old Apr 25, 2000 | 09:44 PM
blue_banshee's Avatar
if u still have the stock carbs, the litte black hose that runs in between both carbs, it may be disconnected. make sure it is connected.
Old Apr 25, 2000 | 09:49 PM
mongoose's Avatar
does it run? if so, try to turn in the silver screws on the big cable housing above the carbs. that should turn up the idle. but be sure to turn them BOTH in the same.
Old Apr 26, 2000 | 12:43 AM
blake350's Avatar
i ahve stock carbs ill try both what you guys say and see what happends...thanks, but everything seems to be connected we dont understand whats wrong...
Old Apr 26, 2000 | 09:43 AM
fakie99's Avatar
if you have the throttle cut out system (TORS) on top of the carbs, that is most likely the problem. i had the same thing happen on my banshee and it turned out that the tors system was cutting out my ignition at idle because the sensors were not working properly. motion-pro makes a kit to remove the stock system and replace with striaght cable. i HIGHLY recommend it. hope you solve your dilemma.
Old Apr 26, 2000 | 11:38 AM
blake350's Avatar
how much does that cost?
Old Apr 26, 2000 | 11:52 AM
fakie99's Avatar
i think i paid about $50 for the kit. you need to drill the side of the carbs and install idle speed screws, which are included with the kit. (becuase the TORS units control the idle speed and, with them removed, the carb slides just bottom out.) the whole install only took about an hour and it was pretty straightforward. well worth the money and time. i think motion pro has a website if you want to check it out.
Old Apr 26, 2000 | 02:08 PM
sAyIt_fmf's Avatar
These are mechanics that did your top end?
It should be their problem to get it running for you...
I would get rid of the tors though...and try the motion pro idle kit as mentioned above...It works great and cleans up those honking tors units on the top of the carbs....
your sure the carbs are synchronized and the jetting is close.?
Look into the intake on the carbs and make sure the slides are lined up.....If one is off...that could be the problem too(synch)
Old Apr 26, 2000 | 03:17 PM
wolv09's Avatar
chech the carb intake rubber boots that house the reeds they are known for cracks on the bottum side spray ether arond engine if it will run possible vac. leak
Old Apr 26, 2000 | 03:57 PM
blake350's Avatar
THEY ARE GOING THROUGH IT NOW, AND I TOLD THEM EVERYTHING YOU GUYS HAVE SAID, BUT I DONT KNOW IF I CAN JSUT GET ROD OF THE TORS SYSTEM I HEAR IF U CUT THE WIRES IT MAKES ALOT OF PROBLEMS...
