Dynojet kit
Old Apr 12, 2003 | 04:26 PM
wshrdskin's Avatar
Default Dynojet kit
Do what the instructions say.
Here is the online instructions incase yours are hard to read.
Dynojet Kit
Install the Dynojet needles on groove #4 from the top, using all stock spacers. Install the Dynojet slide springs (DSP026) in place of the stock slide springs . NOTE: The DSP77 springs do not have to be used, they are supplied in case the stock springs are misplaced.
If you are running an aftermarket slip-on exhaust with a high flow baffle, use the
DJ144 in the left carb and the DJ146 in the right carb below 3000 feet
Your removing the baffle so go with the after market slip on instructions. If you have a K&N pro design or a pro design foam filter and run with no lid you might want to use the 146/148 jets, it may not be nessessary though.
chop
14
Apr 26, 2001 03:02 PM
DSAPP
Jan 31, 2001 08:34 PM
nightlife7810
Oct 17, 2000 04:36 PM
CG400exMaster
Sep 25, 2000 12:17 PM
RVonSand
Dec 2, 1999 11:41 PM
