Banshee question?!
Old Apr 12, 2003 | 07:12 PM
CamBan's Avatar
Default Banshee question?!
I just finished installing a Pro Design pro flo intake on my stock 2002 Banshee. After installing the new filter setup I started it up and let it warm up and took off. Anything past half throttle it just bogs and sputters. I was running without the lid, (which I would like to keep off). I am using the foam filter, and I had just oiled it. I am running a 220 main jet. Is this the right size jet? Anything else that would cause the bogging? Your responses would be appreciated. Thankyou in advance.
Old Apr 12, 2003 | 08:38 PM
Sandtrax690Raptor's Avatar
Not sure on what size you need to go with but is does sound like a jetting problem.
Old Apr 12, 2003 | 09:42 PM
CamBan's Avatar
Can anybody help? Any suggestions would be appreciated. Thanks!
Old Apr 12, 2003 | 10:24 PM
dsguru's Avatar
Camban I would put a 270or 280 main jet turn the air screw in half turn go from there.It was about 55f out when we tested it.We had the same problem until we got the right jetting the it work goooood!!!!!75mph good on radar.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 12, 2003 | 10:50 PM
CamBan's Avatar
I will try that first thing in the morning. Thanks again for your help.
Old Apr 12, 2003 | 11:21 PM
dsguru's Avatar
Camban let me know how you make out.
Old Apr 15, 2003 | 04:49 PM
BitchenBanshee's Avatar
you need a bigger main, try 270 to 280
Old Apr 15, 2003 | 06:32 PM
WyoDuner's Avatar
270 or 280 sounds a little big without pipes. Maybe 240 or 260??? Experiment though - every machine is different.
Old Apr 15, 2003 | 06:35 PM
Ernie660R's Avatar
290 or 300, 3 clip. Depending on elavation!
Old Apr 16, 2003 | 02:44 AM
DunePilot858's Avatar
On a stock Banshee with K&N no lid with stock pipes I rejetted to 30 pilots new needle and 290 main jets at sea level. I tried 250-270 and they were way too lean even for the stock pipes. 290's were a little rich but it ran well and didn't bog at all.
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
mark23
Oct 1, 2015 09:57 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
