raptor sprocket hub HELP!!
Old Apr 14, 2003 | 06:11 PM
Grim2Jolly's Avatar
Default raptor sprocket hub HELP!!
is there a way to tighten the sprocket hub and brake rotor on the stock axle. mine are starting to get loose and i don't know a whole lot about the axle and bearing carriers and stuff. any help would be appreciated.
Old Apr 14, 2003 | 08:58 PM
badchad's Avatar
Grim - it sounds like your axle nuts may be loose if you have play in the sprocket and rotor hubs. Try to tighten it up a bit and see if that helps out. Also, check the condition of your bearings in the carrier. It would be best to lift your quad up and see if you have any play in them.
bmxatv10
Oct 14, 2022 06:23 PM
buddieboy
Dec 9, 2016 05:50 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
