banshee jetting
Old Apr 16, 2003 | 09:24 PM
  #21
miniblaster's Avatar
Default banshee jetting
ok, well i put 310's in today, and it seems to run kinda doggish and its hard to keep the revs up when your not really slamming it into gear. The plugs still are about the same color, i guess they just aren't gonna give me a good reading, so i'm gonna put the 300's back in a nd run it. i just hope that she doesn't blow!!!
mini
Old Apr 17, 2003 | 11:35 AM
  #22
WyoDuner's Avatar
Miniblaster, you will be fine with the 300 jets. You basically confirmed this yourself using the same method I and others use. You went up in jet size untill it started ******* then you back down. After you get some time riding - maybe 30 minutes or more you will see some color on the plugs.
Old Apr 17, 2003 | 03:34 PM
  #23
yea, well the thing is i don'r run alot above half throttle, unless we are on a a road(NO DUNES AROUND HERE), and i can't see it cuasing any damage to be in that range for a few minutes even if it isn't perfectly jetted. thx for all the help
mini
Old Apr 21, 2003 | 04:25 PM
  #24
hefe4pres's Avatar
I just bought a 2002 banshee and i feel that i need to re-jet. the dude i bought it from never jetted it. I run with a boost bottle at a 40:1 mix anywhere from 5,000-7,500 feet. Any reccomendations???
Old Apr 21, 2003 | 11:28 PM
  #25
beginnerbansheerider's Avatar
hey, yall sound like yall know a pretty good bit about a banshee.... see if you can help me right quick...... ok, i have a 2001 banshee that i just bought off of a boy.....i brought it home to crank it up and it would crank but when i gave it gas it would not get any gas.....i cleaned the carbs and things and it still did it......I asked some other men who knows alot about banshee's and they said it sounded like the ingition box..(or i believe it is called the cdi box)....what do you think it is...........P.S. when i give it gas it bogs down till it shuts off..........sometimes it will not even start!!!! please help me man
Old Apr 22, 2003 | 05:12 PM
  #26
WyoDuner's Avatar
Miniblaster - sounds like you'll be fine.
Hefe4pres. If you Banshee is stock you will riun about a 180 main jet. With K&N filter about a 190 main jet at youir altitude. The boost bottle doesn't affect jetting (or anything else for that matter) so don't worry about it.
Beginner, could be related to the TORS or the parking brake switch is stuck. I recommend a search on the subject as it's too much for me to cover right now. If it starts up at all then your CDI should be fine. The TORS and parking brake switch limit the RPMs as a safety measure. You give it gas but it won't rev and sputters and sounds real sick.
Old Apr 22, 2003 | 06:52 PM
  #27
Batoutahell's Avatar
Beginner, sounds like it is not getting fuel, or could be the parking brake as wyo stated. But it really sounds like it is not getting enough fuel. Or if you run your carbs out of fuel.
Hefe, what mods to the machine?
Bat
Old Apr 22, 2003 | 08:06 PM
  #28
hefe4pres's Avatar
i know that i want to get some pipes for it but i'm gonna have to save up some cash!!! [img]i/expressions/face-icon-small-frown.gif[/img]
Any suggestions for an all around pipe? And does anyone know the number formula for jetting for altitude. is it lean 2 jet sizes for every 1,000 feet??? not sure, just using 2 as an example. Soo i ride at an average of 7,000 feet, and i have the stock jetting. Any takers?
Oh and what about a degree key for a cheap mod?????
thanks
Old Apr 23, 2003 | 01:34 PM
  #29
WyoDuner's Avatar
hefe4pres,
Good all around pipes are Toomey T5, Pro Circuit and FMF SST pipes. Dyno runs on those all look pretty good but they are top end pipes. The mid range pipes seem to not add much midrange and hardly help top end so I don't personally think they are a good choice.
Degree keys are an OK mod and are cheap - $25 for the key and another $10 for the puller (mandatory).
Jetting is unique to every machine, temperature, altitude, etc.... Let us know what you got and we can help you out. I ride around 7000 feet a lot too so I know what works for me.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
