banshee main jet 310 sound right?
Old Apr 16, 2003 | 12:54 PM
  #21
bigstatik's Avatar
Default banshee main jet 310 sound right?
i took all that apart and put it back together more than 5 times already, no leaks and its all perfect, u could eat off the carbs.
Old Apr 16, 2003 | 12:57 PM
  #22
garyc660R's Avatar
Did you spray through all passageways too ensure they are open? What about the carb tops and the TORS crap.....my brother had the same problem once.
Old Apr 16, 2003 | 12:59 PM
  #23
bigstatik's Avatar
yes i had it all apart and its all fine. it was revving all the way on the 1st couple of days i had it.
Old Apr 16, 2003 | 02:11 PM
  #24
Batoutahell's Avatar
You say the machine is new? take it back to the dealer if it is? Let them fix it.
If the fuel is old, might be something to check.
You have the slides in the correct carbs right? correct float bowls on right? The bowl with the brass tube goes on the carb with the choke.
You said it has a timing plate, maybe someone put it in wrong, or messed something up with it, worth checking out.
Otherwise, you have me stumped also. Might ask over at the banshee hq site, maybe someone had the same problem.
Later
Bat
Old Apr 16, 2003 | 03:58 PM
  #25
bigstatik's Avatar
brand new but bought used a a guy rich fellow who bought it modded it and didnt even break it in.
ok here is the latest, drained all the 24:1. put 32:1 in feels like it has more power in the range where it doesnt bog, but the bog is still in the same spot.
1/3 to 1/2 and up is all bog and i never would hold it in the bog to long, but just now just to see, i held it there and after the bog, it seems to become a miss, or detotation or sputttering kind of backfire. pulled the plugs, nice brown tan color, one is always the slightest bit lighter, but they are far from rich and definately not specked or white.
would the carbs be out of sync cause this?
its gotta be something so dumb.
some please help me!!!!!!!!! ACK!
who ever figures it out get a 6 pack!
thanx
Old Apr 17, 2003 | 03:23 PM
  #26
bigstatik's Avatar
its all back together, everyone on here says its jetted properly, plugs look good. its sill has the loss of power 1/2 throttle and up.
i checked everything over and over again, only thing left is timing, can that be it?
after that i am stumped, because i know it aint the chain wax, or the color of the air in the tires.
some who lives near me come fix and I'll hook you up with a hot girl (dead serious). heh
thanx
Old Apr 17, 2003 | 03:25 PM
  #27
garyc660R's Avatar
Try taking the timing plate off and see how she runs.....what have you got too loose?
Old Apr 17, 2003 | 03:30 PM
  #28
bigstatik's Avatar
i just called dutchess recreation, a yam dealer.
he told me has to be the main jet and to go higher than the 310, .........feedback on that?
Old Apr 17, 2003 | 03:36 PM
  #29
garyc660R's Avatar
Would'nt hurt too try larget mains....at worst, you foul a plug.
Old Apr 18, 2003 | 10:01 PM
  #30
DunePilot858's Avatar
Check your reeds for a cracked or missing piece. Check the carbs for plugged up jets. Make sure the tube between the carbs is connected. Check the vent hose on the gas tank for kinks or obstructions. Swap the plug wires from one side to the other. Tighten the parking brake on the rear of the quad. I'd have to see/hear it in person to know whats really going on.
