Best Way To Change Rubber
Old Apr 24, 2003 | 08:51 AM
shmoo's Avatar
Default Best Way To Change Rubber
Which is the best way to take the rubber off a rim and put new rubber on.(Big screwdriver pry bar etc.) I have never done this before as this is my first ATV so any tips would be gretly appreciated.Cheers [img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 24, 2003 | 08:52 AM
Ward660R's Avatar
Watch it this is a family forum.[img]i/expressions/face-icon-small-wink.gif[/img]
I have never had ANY luck trying to change tires myself. I am sure there is a way but I don't know it.
Old Apr 24, 2003 | 09:32 AM
shmoo's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img] I get it now.lol
Old Apr 24, 2003 | 10:00 AM
NotuRaptor2's Avatar
You MUST have a beadbreaker as seen in the ATV mags. If you weigh less than about 180lbs, you might need help breaking the bead. Work your way around the rim slowly. You won't even think your making progress for the first pass around the rim.
Fronts are easier to change than rears.
If your tires are destroyed, you can cut them off and get new rubber on with just a set of tire spoons.
/NotuRaptor
Old Apr 24, 2003 | 10:07 AM
shmoo's Avatar
So it's good to say to just bring them to a shop.I wanna keep the stocks,thinking of studding them.
Old Apr 24, 2003 | 10:42 AM
sixsixT's Avatar
Yeah, bring it to a shop or buy a beadbreaker.
Old Apr 24, 2003 | 02:51 PM
upnort's Avatar
Ok make sure all air is out. Lay the assembly down on the ground preferably hard ground. Get in your truck (a car will work too). Drive over the tire as close to the rim as you can. I use the front of the truck as it is heavier, sometimes the back will not do it. I learned this in the army and after fighting with my tires tried and it works great. It does not damage the tire at all. I kept my take offs to put back on when I traded mine in.
franklyme
Oct 21, 2016 07:18 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
lancemll88
Sep 6, 2015 03:03 AM
lancemll88
Sep 5, 2015 03:16 AM
