dYNA IGNITION?'S
Old Apr 30, 2003 | 05:17 PM
RacinJason's Avatar
Default dYNA IGNITION?'S
Did they fix the problems they were having with the boxes "shorting" themselves to death when the teather is pulled?
What settings are you guys running and has anybody messed with making your own curve?
Old Apr 30, 2003 | 05:23 PM
BlueLeader's Avatar
I like curve #3 (most advance) for all around fun.
I like curve #2 for drag racing. Good advance in the low and mid rpm and it tapers off on the top.
Old Apr 30, 2003 | 05:32 PM
RacinJason's Avatar
I saw two part #'s one for the 01 and another for the later years...whats this all about...and how does it compare to stock CDI?
Old Jun 18, 2003 | 08:29 PM
Hiram's Avatar
How else is using the Dyna FS ???
Old Jun 19, 2003 | 08:19 AM
GregV's Avatar
What you need to do is take the lead off of your ORANGE wire on the positive side of the coil and extend the long enough to reach the DYNA CDI box. Then install a round push-in connection and insert it into the PURPLE/WHITE connection on the new ignition. It works fine. The ofther end of the kill switch wire I left on the NEGITIVE side of the coil. It worked great.
I haven't had a chance to a lot of testing yet, but I started out on the #4th. (stock position) just to be safe at first. Then I switched it over to a curve that I created. It felt great, I can't wait to get it back in the sand and see how it does. [img]i/expressions/face-icon-small-smile.gif[/img]
I also added a Tach. while I was at it.
Old Jun 20, 2003 | 12:38 AM
RaptorRacer1's Avatar
As GregV said, the problem is not the Dyna box, it is the method of installing your kill switch. One wire to ground, one wire to the purple wire on the Dyna box.
RR1
Old Jan 17, 2005 | 02:26 PM
nitrousoxide's Avatar
Hello GregV!
I read your old message from Jan. 2002.There you write that you have an dyna fs on your raptor and you added a tach. Where you bought that tachometer?I´m searching for a tachometer which I can attach directly to the box.A digital tachometer is better for me.Have you some links to buy a tachometer?
Thanks
Old Jan 17, 2005 | 02:31 PM
Dfitz's Avatar
nitrousoxide
Did you change your rod for the 727?
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
kbazzy
Sep 26, 2015 11:26 AM
Sw00p
Sep 24, 2015 02:50 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
