Hensim 2007 150 cc Quad GY6
Old 04-30-2013, 02:12 PM
vcorabi's Avatar
Default Hensim 2007 150 cc Quad GY6
Need some help! Just bought this quad and reverse works fine but forward grinds and pops out of gear and dont know where to start. Cant find a shop that will work on a chinese quad and hope someone can give me some advise on how to fix myself or a shop in the PA / NJ/ DE area I can take it for service?
Thanks
Vincent
Old 04-30-2013, 03:06 PM
Jaster94's Avatar
i'm not real familiar with the hensim, is this the automatic? CVT? or is it a semi auto transmission?
Old 04-30-2013, 04:05 PM
vcorabi's Avatar
Yes from what I am reading its cvt auto. Has forward, neutral and reverse.
Old 04-30-2013, 08:07 PM
Jaster94's Avatar
these transmission ain't hard to fix. it almost sounds like someone has been forcing it in to forward while the RPMs are up. did you buy it used or new? i'm presuming used. look at my album and you can see the inside of an Eton CVT/Automatic transmission. then you can decide if you want to tackle it yourself or have it done. let me ask you this, when the quad is dead, put it in forward and push it around. does it jump or grind then? does it feel like gear teeth are stripped? how fast are your idling RPMs?
Old 05-02-2013, 03:17 PM
vcorabi's Avatar
Turns out the shifter / linkage was in need of adjustment. Thank you for your help.
Sjrpp
05-02-2023 03:59 PM
Sjrpp
11-15-2019 09:59 PM
Sjrpp
06-02-2019 07:25 AM
DOC HOLIDAY
07-09-2015 01:09 PM
Sjrpp
07-05-2015 09:04 PM
Quick Reply: Hensim 2007 150 cc Quad GY6
