Arctic Cat Side By Sides Talk about all the Arctic Cats, Sport and Utility
Trickle Charging
Old 12-28-2007, 05:15 PM
articrider's Avatar
Default Trickle Charging
I use my Prowler every 2-3 weeks and the battery tends to get weak. My Harley Softail has a trickle charging plug for period of low use. Any ideas on connecting the same type of thing to the Prowler or even better CAN YOU TRICKLE CHARGE A PROWLER THROUGH THE 12VDC POWER CONNECTION (i.e. old days cigarette lighter) without direct connection to the battery. Should work?
Old 12-28-2007, 05:22 PM
smooth1's Avatar
I picked up a battery tender for my wheeler......it came with a pig tail that you leave connected to the battery......when you leave it for long periods just hook up the pigtail to the tender and plug it into the wall outlet.............
it senses when the battery needs charging and will keep it at a full charge......
Im not sure if charging thru the power connection will work?
Old 12-29-2007, 02:03 PM
kempre's Avatar
... buy a charger?
you should be able to charge through the dc outlet but you would be better off directely to the battery
Old 12-29-2007, 02:12 PM
ctateusa1's Avatar
battery tender makes several different types of trickle chargers that you could pick up and just plug and go
ReconBayou
10-31-2022 05:37 PM
speedbuff
13
11-11-2020 10:16 AM
shimanok2
01-29-2016 07:37 PM
cswiger
Polaris Side by Sides
12
10-05-2015 03:34 PM
Jersey General
1) Engine problems..
09-13-2015 01:05 PM
Quick Reply: Trickle Charging
