Help please
Old 10-12-2009, 04:41 PM
gades27's Avatar
Default Help please
Hey guys, anyone know if you can put the whole front of the model 2006 to 2005 model? know if someone has done? greetings.
Old 10-13-2009, 04:21 PM
Williebee's Avatar
Post Help please
First off Welcome to the forums gades27 !
I don't know for sure if you can interchange the 2005' to the 2006 models , but AC did some changes to the 2006' model #1 they mounted the fuel tank in the rear under the seat ; and if i'm not mistaken (and i don't think i am ) the 2005' model had the fuel tank mounted on top between the seat and handle bars #2 the 2006' model only has a removeable storage compartment to get to the air filter element .
If you take a close look at the bottom photo you can see part of the fuel tank in the rear between the left rear tire and the plastic's .
Someone who know's more about the 2005' model may jump in and give you a diffenent answer on these 2 model's , i hope this is of some help ; and again welcome to the forums !
williebee........
Old 10-14-2009, 03:41 PM
gades27's Avatar
As the gas tank had not noticed me, because one will have you up and the other back, but hey I thought it could change the front alone, have someone explain to me know if you can or not, greetings and thanks.
Old 10-14-2009, 03:52 PM
scootergptx's Avatar
Supersock
Hired Gun!
Just looking at it I'd have to say it would be a lot of work. Plastics are different so you'd be changing the more than just the front end. Seats look different too. Rack mounts seem to have different locations as well.
