2004 Arctic Cat 250 start help needed
Old 09-20-2014, 02:45 PM
matthewpoop1's Avatar
Default 2004 Arctic Cat 250 start help needed
Hello i have a 204 arctic cat 250 quad 2x4 and it keep trying to start i replaced the spark plug and it started for a few sec. now i got another problem i keeps trying to start like the start button is stuck watch this video to see also im not pressing the start button its doing it by itself
https://drive.google.com/file/d/0B4U...it?usp=sharing
Old 09-20-2014, 08:51 PM
Not too familiar with Arctic Cat(know the old ones had Suzuki engines I believe),but have had some Polaris models do this also.It can be the starter switch as you mentioned sticking or a solenoid itself shorting out. If you can take the switch apart,I'd check it out first.Contacts may be touching.Don't know if these have a starter relay also that can short out?
Old 09-21-2014, 02:50 PM
I bought a new solenoid so it might be the switch let me check
Old 09-27-2014, 02:26 PM
So i replaced the switch and still wont start it turns but doesnt start
Old 09-27-2014, 03:07 PM
Then I'd ground out the plug to engine and see if you lost spark. Best to have a manual on trouble shooting electrical problems rather than throw any more parts at it. Here's a link to a free pdf manual I believe works.Toward the bottom is the down load button.2004 arctic cat 250 300 400 500 atv repair manual.pdf
Old 09-27-2014, 10:24 PM
i have the manual.. it started then when i gas it some gas it shut off
Old 10-05-2014, 09:49 PM
Kevin McKenney's Avatar
Have you tried fresh gas?
neilbedwell
11-10-2018 11:02 AM
TegraQuad
1) Engine problems..
13
11-26-2017 01:40 PM
jrooker6
Ask the Editor
11
04-21-2016 07:35 PM
garyt1975
06-05-2015 08:53 AM
1000gade
05-27-2015 12:37 PM
Quick Reply: 2004 Arctic Cat 250 start help needed
