2004 400 atv auto carb prob
Old 09-05-2016, 02:25 PM
jplowing's Avatar
Default 2004 400 atv auto carb prob
this unit would warm up a little and then you hit the throttle and it bucks spits kinda backfires, and wont idle, restart will idle but give it gas it dies,iam rebuilding the carb, am i headed in the right direction or what other issue would this be thanks for any help
Old 09-06-2016, 11:12 AM
DirtDevil101's Avatar
carb rebuild is a good idea, but also throttle cable and any electronics related to throttle (you didn't provide make/model so hard to help further)...
Old 09-06-2016, 01:14 PM
jplowing's Avatar
all i know about model right now is that it is a 2004 400, auto, with the 2 wheel drive option, i see alot of info that there is a 2 by 4, and a 4 by 4,did they make a 2 wheel drive atv, or are they refering to the 4 by 4, with the 2 wheel drive option,thanks for any help
Old 09-06-2016, 02:46 PM
pic?
Old 09-07-2016, 06:41 PM
jplowing's Avatar
i dont know how
Old 09-08-2016, 10:57 AM
select "go advanced" and then attach the file (paperclip icon)...
Old 09-09-2016, 10:44 AM
jplowing's Avatar
tried again i upload the pic
Old 09-09-2016, 11:42 AM
It's a 2004 Artic Cat 400 4x4 Auto.
access to service manual is (choose 2005 folder):
http://www.mymowerparts.com/pdf/Arct...rvice-Manuals/
From your description sounds like fuel is not getting into the carb bowl or your float needle is stuck closed...
Old 09-13-2016, 07:24 AM
jplowing's Avatar
thanks for the info, i rebuilt the carb cleaned the fuel system added a fuel filter, and it is running great i put 50 miles on it yesterday, can you tell me about how many miles per gallon these get, it seams with the cvt trans that these units will burn more gas then normal unless somebody knows different, next i will change oil and filter and ride,thanks for any input on my atv
Old 09-13-2016, 07:47 AM
hydrex's Avatar
Those are a stout machine, I have the manual shift version. I've noticed that my mpgs got better after installing a "Dynojet Stage 1 kit", power too, I can hit 57 mph now, before 52. Keep an eye on the boot between air box and carb, if they crack, can run lean and injest water and mud. If you need wheel bearings try to find the Koyo ones, not Chinese.
Quick Reply: 2004 400 atv auto carb prob
