1982 Honda atc 250r
Old 05-26-2010, 12:01 PM
1lightningd's Avatar
Default 1982 Honda atc 250r
Hi I just bought a Honda 250r trike and I am having trouble with the fuel mix, the sticker on the tank says 20:1 petrol (gas) to oil but it wont run right for me? The bike has had a complete engine rebuild with new gaskets and seals. The barrell has been bored out to suit a new larger .75mm wiseco piston. It has new EBC friction plates and clutch springs with a new clutch cable. The work on the bike had been carried out by the last owner so would this make a difference to the mix? I read somewhere that people were using 32:1 mix, is there any rule on this or is it a case of trial and error? Any help would be appreciated. Alvin
Old 05-28-2010, 12:25 AM
4bratsdad's Avatar
i run 32/1 heard of guys runnin 40/1 i have a 84&85 250r when i got my first one the 84 the kid i got it from was runnin the 20/1, the 2 stroke oils are a much better quality now than they were in 82, mine ran like crap w 20/1, pipes were full of oil ,it was blowin it out the end.
Old 05-28-2010, 07:07 AM
Thanks for the reply 4bratsdad, I will try the 32:1 mix and see how I get on, but I now have another issue, the gear selector is moving on the shaft and not selecting gear, the grip treads are worn too much so I must get a new one, someone did suggest welding it too the shaft, but I would prefer to get the right one for it. Where do you guys get your parts? Alvin.
Old 05-28-2010, 03:32 PM
4bratsdad's Avatar
go to ebay type in honda 250r atc make sure it says for your years, pretty sure the 85-86 wont work, not real sure if the 81-82 first generation 250r will work with 83-84 2nd gen 250r, check out air foolers .com whole site dedicated to air cooled 3 wheelers
Old 06-02-2010, 04:36 AM
I managed to find my way over there to that site 4bratsdad, Thank you, lots of useful hints and tip's for someone like me!
Old 06-02-2010, 03:43 PM
4bratsdad's Avatar
glad i could help, just bought my first atc250r few months back,2nd 1 last week its an addiction, lookin to buy a parts lot from couple guys, maybe i could sell some get my money back, anything you need let me know, this guy ive been dealin with has some 81-82 stuff ,all air cooled250r, i saw a chrome heat guard on a stock 81-82 head pipe, lots of engine parts let me know
Old 06-26-2010, 02:24 PM
'83-250r's Avatar
Default mix ratio
i just bought a 83 250r for 750$ and i run 50:1 and its perfect, its a little rich but thats what you want.
Old 06-26-2010, 02:26 PM
'83-250r's Avatar
Default Oil level
Does anyone know how much oil i should put in my 1983 250r, please respond!!!
Old 07-11-2010, 05:05 PM
MadMel777's Avatar
'83-250r do you need to know how much trans oil you need ? there's a plug in the left side case marked "fluid level" i believe...take that out and with the trike on level ground fill it till it weeps out the hole and your full
Old 07-11-2010, 09:10 PM
'83-250r's Avatar
yea i figured that out shortly after i posted that but thanks anyway
NewGuy2481
10-06-2015 05:54 AM
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
Jason Campbell
09-07-2015 02:25 PM
Quick Reply: 1982 Honda atc 250r
