ds650 starting problem HELP
Old 03-07-2006, 06:48 PM
rfwlll's Avatar
Default ds650 starting problem HELP
Hi ganggreen. My problem I beleive was not having a good charged battery. I would try hooking up a set of jumper cables to a good battery if you havnt yet. Do not try using a battery charger because that may burn something up, it did burn up my tach. I have not had that problem since I put a new battery in and used a good battery to jumpstart it. Let us know what you come up with and I hope this helps. RUSS
  #32
Old 11-21-2006, 11:21 AM
bubblebutt's Avatar
my bike was doing the same thigs. i finaly found out what was wron. its not getting any spark, but all the wiring is perfectaly good. pull your plug, stic it in the coil, put the bottom of the plug up to ground(engin will work), if there is no spark then there is your problem. now just find out why. my bike is a yfz450 but they probly work the same.
  #33
Old 11-21-2006, 06:39 PM
rfwlll's Avatar
Hmmm. You must not of read the post. LOL, it's ok it is fixed, and it was because I did'nt have a good battery. Welcome to the forums. RUSS
  #34
Old 12-31-2011, 05:17 PM
White Knuckling DS650's Avatar
Default Crank case pressure !!
Hi everyone I have a 2000 DS650 and it cranks over very slow even with a new battery. Just by accident i noticed when i leave the stator cover loose it cranks over fast and starts right up. It seems to be blowing compression into crank case causing it not to turn over fast enough unless left loose so it can release the pressure. Any help would be great Im new to Can-Ams
  #35
Old 07-21-2013, 05:26 PM
thebigshow's Avatar
Bump
  #36
Old 07-24-2013, 10:30 PM
O2x4's Avatar
Carge battery, check valves&timing, check spark, check fuel, check air restrictions. Hold that sucker WIDE OPEN THROTTLE and hold down the start button till it fires up.
  #37
Old 09-10-2016, 10:58 AM
Raidertim's Avatar
Hey guys I'm new to this forum!! Hope I'm doing this correctly. I just bought a 2000 ds 650 baja. It had been parked in the weather for a year. The crankcase was full of gas so u drained the oil tank,crankcase, and put new atv oil in it and filter. I also put 2 new spark plugs in it and have been using my battery from my king quad 450. When it is cold I have to lay on the starter button without letting off and hold the throttle wide open after a minute or so of this it will begin to pick up then all of a sudden wham it starts Erving and running and will idle. I can take off and ride it and stop and shut it off and it will fire back up. But after a few minutes of riding the oil light will faintly come on to where h can hardly see it. It also has came on fully twice and I shut it down. Also it doesn't have the power it should have. But I was hoping the starting issue and the power may be 1 and the same. Sorry if I ha end explained good enough I'm really puzzled. I also flushed and changed the coolant. And I also used the screw by the filter when I changed oil. Any help would be appreciated!
  #38
Old 09-10-2016, 10:59 AM
Raidertim's Avatar
I'll be more careful with my auto correct misspelling everything!
  #39
Old 09-10-2016, 11:03 AM
Raidertim's Avatar
The guy said he parked it cause it needed a battery then the carb leaked the gas in the crankcase and it sit that winter.
Yamaha_
Utility ATVs
12-16-2022 07:49 PM
generalpops
06-05-2015 08:23 PM
garyt1975
06-05-2015 08:53 AM
generalpops
06-03-2015 08:25 PM
1000gade
05-27-2015 12:37 PM
Quick Reply: ds650 starting problem HELP
