HELP traxter 500 low compression
Old 03-02-2010, 08:16 PM
brindley's Avatar
Default HELP traxter 500 low compression
Im working on a 03 traxter 500, I cant get over 30psi of compression. I replaced the piston and rings still only 30 psi. so i pulled it down measured the cylinde it was in spec but border line, so i sent it off and had it replated, also ad the seats and valves cut in the head. got the cylinder back today with hopes of getting it running installed piston cylinder and head left the rockers and push rods out to elimate it being the valves or the cam still 30 psi.. what now? I did a search were someone else had similar problems but never was a answer any feed back saying they figured it out.
Old 03-02-2010, 08:45 PM
brindley's Avatar
just did a leak down test and it is less than 20% so that is good
Scooter's Shop
10-09-2015 02:09 PM
CosmoM
09-21-2015 04:57 PM
Ricardo Covarrubias
09-17-2015 08:28 AM
Nosniborpapa
09-12-2015 05:54 PM
Steeldon
09-09-2015 09:38 AM
Quick Reply: HELP traxter 500 low compression
