Dinli Carb Question
Old 10-04-2013, 08:15 PM
GBrown's Avatar
Default Dinli Carb Question
I'm pretty sure the carb on my sons Quad is having some fuel delivery issue but I can't tear it down because to date I haven't found replacement gaskets for it because I can't identify it. Hoping somebody would know and chime in with some info about it or maybe even a easy to tune replacement carb for it. It's a 2003 Dinli Diamondback 90cc Quad. It runs great at idle all day but seems to stumble & bogg when I thumb the throttle. I'd like to simply replace the carb with a simple/EZ tune replacement but don't know which to buy. Also, a lot of the Carbs I've seen online have what appears to be some sort of plug connector. Would that be for an electric choke ? The Dinli that I have has a manual choke lever on the left side of the handlebars. Any guidance or replacement ideas would be greatly appreciated and a big help.
According to the little info I've in the Dinli Manual it may be the wrong carb because my info shows a different style carb on the 50/90 cc Dinli's .
Old 10-05-2013, 11:01 AM
Zrock's Avatar
Super Quad Patrol
if you check ebay you will find lots of carbs with a manual choke. If you are careful and take your time you can pull the carb apart without damaging the gaskets. You can always use a little rtv silicone and wipe a little on the surfaces where teh gaskets go and you will have a better sealed carb. I did that with mine and works great. just remember to let it dry for 24 hours before putting gas through it
Old 10-05-2013, 12:51 PM
GBrown's Avatar
Thanks for responding......
Have you seen that type of carb on a Dinli or other Chinese Quad before ?
The Dinli manual that I have shows a different carb on the 90cc Quad
Old 10-06-2013, 10:28 AM
Zrock's Avatar
Super Quad Patrol
no but i just got back into the sport after many years out of it
Jmuddin284
06-28-2017 04:59 PM
200es
07-10-2015 09:09 AM
tweeder
07-05-2015 01:57 PM
yambam13
07-04-2015 01:49 PM
Mikea1978
07-04-2015 12:37 PM
Quick Reply: Dinli Carb Question
