Meerkat 50 remote kill switch
on
I would bet they want you to say it is a "normally open" Run/Stop switch. The switch is open when running. and when closed the ignition system is shut down and the engine stops.
The real question is what is the definition of "normal". Is the "normal" condition stopped (shut off), or running? It spends a lot more time shut down (which is one definition of normal), but it is normally only useful when running. One could argue both ways.
Does you CDI module look like this?
The wire you want to tie into is the "kill switch" conection. The wire often goes to several kill switches, any one of which when shorting this line to ground kills the ignition (and therefore stops the engine). [Other kill switches may include one half of the 2 pole ignition switch, the handle bar kill switch, and a tether cord pull kill switch.] Kill switch is just another name for Run/Stop switch.
Usually this wire is black with a white stripe on it, but not always.
Hi LD.
I'm down the road in Fermanagh. I've just removed the kill switch from the rear of my daughter's quad - no longer needed. It's the standard type where you follow behind and pull a (long) cord if she goes mad! If it's any good to you you're welcome to it - send me a message. A lot of these wee quads are already wired for a rear mounted kill switch (a second run/stop switch in effect, just wired across the switch on the handlebars) so check for two spare wires at the back before you hack into the loom! Sounds like you are where I was a while ago so good luck to you in any case...
Cheers, Paul.
Cheers, Paul.
