Falcon 150 broken rear axle
My son was riding up a small sand dune and turned hard right to spin the back end out and ended up breaking the right hand axle right where the wheel hub splines start. The bike has paddles and I run 10 gram rollers in the CVT. I am thinking that there was too much stress on the axle in the tight turn and the weakest link broke. I am concerned that it will happen again if I put the same OEM axle back in. I don't want to de-tune the bike but I am thinking of increasing the turn radius by modifying the steering shaft stops and decreasing the stress put on whatever axle is on the inside of the turn.
Thanks
Thanks
If you have it apart and know the specs. etc. you maybe able to swap it out with another chinese manufacture like say Jetmoto or something. I believe on the Jetmoto the axle might be the same on the 250 and 150. AS we all know not everything is the same from China in some cases.
What I'm saying is if you can bolt a 250 axel on there one would think it would be strong enough for the the little 150 to handle.
Thanks
Thanks
DeFox500
08-14-2015 05:59 PM
