90cc w/reverse
Could you some how get a nut on the threaded shaft to keep it engaged?
If i pull up on the shaft then it will go into reverse and the shaft stays up. When i shift to any other gear the shaft goes back down. I'm thinking its like this to kept you from down shifting into reverse while still going forward, would not be a good thing. I'm thinking maybe some quads had a cable to pull it up when you wanted to use reverse. The shift patten is 123NR up.
What keeps yours from going in reverse when going forward?
Thanks for the reply.
My shift pattern is up for forward gears(3 on the 125, 4 on the 200 and 250) Reverse is down. It wont allow you to down shift into reverse if the quad is moving.
Chasso
2) Chassis problems..
09-19-2015 03:06 AM
