Zstar 110 - Replace Ignition/Kill switch with inline switch?
Old 04-17-2016, 11:11 AM
AC-Greeny's Avatar
Default Zstar 110 - Replace Ignition/Kill switch with inline switch?
Hello all,
I have been having the usual issues with the 3-position, turn signal-style ignition/kill switch on this Chinese 110. The ATV is full automatic, no key, push starter button, 5-pin CDI, 2 leads to the ignition coil, starter on top of motor.
I want to replace the 3-position ignition/kill switch with this setup:
Could anyone confirm or deny this being functional?
Thanks,
Green.
Old 04-17-2016, 01:08 PM
Not functional. You ether have the key switch feeding live to lights etc, and a separate part of the switch feeding earth to the CDI, so four wires, or a simple on off switch for live if the bike has a DC CDI, so two wires.
Old 04-17-2016, 01:15 PM
AC-Greeny's Avatar
It is DC CDI, it has a 4-pin rectifier hooked up between the stator and the CDI box.
So, I could remove the OEM handlebar switch and just replace it with inline battery on/off switch and inline starter solenoid on/off switch?
Thanks,
Green.
Old 04-18-2016, 10:19 AM
Zrock's Avatar
Super Quad Patrol
You could just get the handlebar switch into the on position and put a push button starter some ware and use the key to shut it off. I bypassed all of that and put a heavy duty starter switch direct to start solenoid and use the key for on off
Old 04-22-2016, 03:05 PM
AC-Greeny's Avatar
Here is how I have it set up, no key:
Old 04-23-2016, 08:51 PM
AC-Greeny's Avatar
I tried it with the wiring setup I posted and it cranked the starter, but almost instantly blew the 15A fuse closest to the 4-Pole Terminal.
Any ideas?
Old 04-23-2016, 09:25 PM
Zrock's Avatar
Super Quad Patrol
15 amp fuse is not enough to turn the starter. My push button is rated for 30 or 40 amps.
Old 04-23-2016, 10:19 PM
AC-Greeny's Avatar
Thanks for the tip.
I will grab some more higher amperage fuses tomorrow and give it another go.
Old 04-24-2016, 10:54 AM
Zrock's Avatar
Super Quad Patrol
also is that 4 pole terminal strip factory? usually the main starter power goes direct from battery with inline fusible link.
Old 04-24-2016, 12:08 PM
AC-Greeny's Avatar
No I put the 4PTS in myself, just to neaten things up.
The starter motor is cranking over fine now with a 40A fuse, so that's all sorted.
Just have to fuel it up and hopefully it runs!
Quick Reply: Zstar 110 - Replace Ignition/Kill switch with inline switch?
