any info on the portable tire changer- harbor freight?
Explanation
The tire changer actually has two pieces of flat steel that are mounted down toward the ground to break the bead...well the steel bent before the bead broke...you will need to have the separate tool that is meant to break the bead. Hope this is a bit more clear...check out the original pic...you will see what I am talking about!
toonces
10-16-2019 12:11 PM
Logan Collins
09-05-2015 08:03 PM
