Polaris Trailboss
Polaris Trailboss
I have a 2001 Polaris Trailboss 325. Recently had a chain go bad and had to ride on it for a day, because of that it tore up both the front and back sprocket. Since, I have replaced the chain, swing arm bushings, and both sprockets. Still, when I give the four wheeler a lot of gas or a quick start the rear end makes a grinding noise and doesn't engage well. It does the same thing when on a hill, just grinds and doesn't engage well. Does this sound like a messed up gear in the transmission? Everything on the back axle is replaced and new. My next step is to replace the transmission fluid and look for medal shards. Thank you for your time.
Probably the internal silent chain has stretched and jumping teeth under a load. Common problem on this models as well as others. Item #38.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Lot of work just to tear the gear case out and split it for this 38 buck chain,but I've done a bunch of them. Always replace the seals also.
Chains are still in the gear cases though,can't do with out them. Hated the old 3 chain outer systems on awd drive machines because of maintenance,but efficient way of getting power to the ground.Now you just have to deal with prop shaft u joints along with cv joints.
A guy at work thought chain drive was better because he could fix a broken chain with a piece of fence wire. Huh? I told him drive shafts don't break so you don't have to worry about fixing it in the field in the first place. He still thought chain drive was better but I don't miss dealing with one. If chains were better than drive shafts they'd put them on cars and trucks too.
