New to my wife '05 Rancher 400
Just brought home this 400 in good condition but needs tires. It has the elec/auto transmission and I want to use 25" tires where it currently uses 24" tires. I would have to replace the rear rim as it is an 11" rim and I would use 12" rims all around. The front is already a 12" rim. My question is can I swap out the taller tire (25" vrs 24")without serious repercussions? Looks like about 5% difference
As long as you keep the same size tires all the way around, going to 25" tires is no problem. Honda puts 24" tires on the new Pioneer 500 side by side. Most people change those out pretty soon after they get it. Its geared so low that it actually improves performance by going with a bigger tire. As far as using 12" rims, I'm sure you can find some older Foreman wheels which I think should fit and you'd have your 12" wheels.
Make sure the off set of the rim is the same. Here is a good rim chart to look up off set and bolt pattern. ATV Tire and Wheel Application Chart : ATV Tires Free Shipping : ATV Wheels : Mud-Throwers.com
