Broken piece behind magneto
But it will rotate as it normally should? Then I would clean up the chip area, fill in with a good quality epoxy such as Marine Tex, and run it. The other choice would be to replace the case half....which is a bit of work....a large bit of work....
Unfortunately, I noticed this morning that it's leaking from the head gasket. They resurfaced the head gasket area when the cylinder was bored out and I double checked the head torque with 2 different torque wrenches so I assume the head may be warped, even though it didn't leak before I took it apart.
That could very well be have been the problem. When I checked the torque on them after running it yesterday I couldn't get them to torque properly, they kept twisting like the bolt was bottoming out before it tightened down.
I think I'll use a real Kawasaki head gasket this time. I wasn't impressed with the quality and thickness of the Namura gasket that came with the top end repair kit. I wondered how something that thin could seal in the first place. New, it was less than half as thick as the OEM Kawasaki gasket I took out of it.
Finally got the correct head gasket for it and all is well, no more compression leak. Apparently the head gasket is different from 1988-up and that's what came with the Namura top end kit. The '86-'87 gaskets are much thicker and have large holes that o-rings fit into that '88 and newer don't have.
