05 predator 90 cold start
Old 12-09-2013, 08:42 AM
rreale's Avatar
Default 05 predator 90 cold start
i have a 05 polaris predator 90. sometimes its hard to start after it sits for a while. i have to plug the air intake on the snorkel with my finger. it idles a litter rough, i adjusted the carb to get it the best i can. i drained the tank, filter is good, cleaned the carb but still tuff to start some times. i removed the bolt in the exhaust, exhaust blew out of it fine. i didnt see a screen in there. the sparkplug is black with some carbon on it. it usually smokes when its cold.
i was thinking of just buying one on on ebay, they are only $25. i believe i have a sunworld h68k carb with manual choke.
the ones on ebay, dont say who makes them. are they any good?
any carbs that might improve performance and are easy to install?
Old 12-09-2013, 09:45 AM
That's how you have to start the little ones if they've been sitting up or it's cold whether it's a manual or electric choke model. We had an 'in house" bulletin from Polaris on blocking the air intake snorkel to make them start in these conditions. Haven't heard any thing bad on the cheap $25 carbs on Ebay,but it's worth a shot as the oem carb is over $300 and the needle and seat assy is around $45.
Old 12-10-2013, 09:02 AM
LT80's Avatar
LT80 Expert
The elec choke models do have their problems. Most opt for the manual choke like you're thinking.
You can try: Hetrick Racing or maximum RPM (both .com). They can sell you carbs.
Old 12-20-2013, 09:32 PM
barrylee66's Avatar
I have put 4 of those cheap e bay carbs on different etons 70s and 90s and a 50. all of them worked great. i wont even clean a carb now. I do remove the bowl and make sure the main jet size matches the stock one.
MikeyBoyesq
11-27-2020 02:44 PM
cbcole02
09-07-2015 06:16 AM
Predator_500
06-13-2015 03:01 PM
bbehrendt
05-28-2015 09:25 AM
1000gade
05-27-2015 12:37 PM
Quick Reply: 05 predator 90 cold start
