Charging system issues
Test the regulator same as the stator wires. Should show some resistance between each yellow regulator wire. If wires zero out,regulator is trash. Tested several regulators this way. I would get a good connector for this from any local auto supply or the site I referenced. Just take one end of the connector in to show the parts guy and they can match a connector up to the size connectors you need.
Looks like that connector was also associated with the RPM cause my RPM's would drop down to zero for no reason when riding. Now it doesn't do that anymore. It was at zero when I had it disconnected. Bettery tested good all seems fine. If that battery still drops voltage than will know problem is somewhere else.
