carburetor leaking gas HELP
Shanghai 150cc ATV, DENI PZ27 carb
It starts well, idles nicely initially, after warm it idles very fast, gas leaks from some sort of over flow tube, if it stalls--it doesn't want to restart, let it sit over night and it starts fine. I have carburetor apart---it is very clean inside. Any suggestions?
DENI carb leaking gas
We got it fixed, pulled the float bowl, found dirt around rubber seat preventing closure of the valve.
Idle is still very eratic---starts off normal, then engine starts to race as it warms up. Have to manually keep adjusting the idle speed.
Thanks for the comeback and information.
fritzal
fritzal
exmotocrosser
09-13-2019 06:12 AM
1ArmBandit
55
10-14-2015 09:03 PM
adjusting, atv, bowl, carb, carborator, carburator, carburetor, dekni, gas, inside, leak, leaking, leaks, pz27, warrior
