Warn RT40 Fit???
Old 06-17-2007, 01:01 PM
SeaRap7's Avatar
Default Warn RT40 Fit???
Does anyone know if the Rt40 will fit the RZR? I assume it will, but looking at the mount area makes me wonder.
Old 06-18-2007, 03:10 AM
DuneDevil's Avatar
Forgive me for being ignorant, but what is a "RT40" and what does it do?
Thanks
DuneDevil
Old 06-18-2007, 04:16 AM
rzr's Avatar
rzr
rzr is offline
my dealer said there was room for the rt30 and polaris makes the mount as for the rt40 if you get it to fit let me know i would like to mount a big winch on mine too
Old 06-18-2007, 11:49 PM
SeaRap7's Avatar
The RT40 is a 4000lb. Warn winch designed for UTV's, but since the RZR is almost 1000 lbs (way more with my butt in it) i thot id go with the bigger winch.
Old 06-19-2007, 03:36 PM
martymoe's Avatar
rzr's have lots of winch room but i think there's an issue with a mounting plate..
on mine i just made my own, the mounting plates for them are really no big deal..
cut an 8x5" piece of plate, cut a piece of 1/8" wall 2" angle iron to 5" weld that edge to your plate, and put some small gussets between the two. then cut a hole in the middle of the angle iron (for your winch line to go through) lay that up in the space above the front diff and mark your holes..
drill your holes then put it back and set your winch and drill it's holes..
it's a little tricky making the mount to hold the fairlead, but not that big a deal..
Jeff Roper
02-01-2022 11:48 AM
toonces
10-19-2015 02:21 AM
panicmanic
09-28-2015 12:59 PM
Erick J. Edler
09-20-2015 05:51 PM
Gtsordo
07-22-2015 01:27 PM
Quick Reply: Warn RT40 Fit???
