Rev Limiter on 1999 Polaris Magnum 500?
Old 10-21-2008, 12:08 AM
hammbone76's Avatar
Default Rev Limiter on 1999 Polaris Magnum 500?
Quick question about this ATV... I have been doing research on it, and can't seem to find where the rev limiter is... Most of the earlier models seem to have a seperate box which looks similar to the Voltage regulator attached in front of the radiator.
According to the wiring diagrams provided by Polarisindustries.com there is not a seperate rev limiter box on this model.
The override button has a Gray/orange wire that connects to the speedometer along with the AWD, etc.
My speedometer has the backlight, but does not show speed or mileage, the AWD doesn't work (I know I can bypass this by grounding the brown/white wire), and I am wondering if the rev limiter is part of the speedo package and causing the motor to bog down at any speed past 1/4 throttle?
If so, how do I bypass the limiter?
Thanks!
Old 10-21-2008, 12:22 AM
TLC's Avatar
TLC
TLC is offline
I would try the search option on this site ,use the "advance" and search "title only". Never had a rev limiter problem but many people may have. I think the 500 Magnum is just a Sportsman with a straight axle,so any results involving a 500 Sportsman would be handy as well.
skinnyr6
08-25-2023 02:18 AM
Cole Hadden
08-24-2020 11:11 PM
Ramman1
06-16-2016 09:07 PM
maxjung
07-13-2015 05:11 PM
jettman
07-06-2015 12:16 PM
Quick Reply: Rev Limiter on 1999 Polaris Magnum 500?
