Scrambler grinds when shifting into gear.
Lower the idle to 1050-1150 rpms and see if helps on the engagement(1350 rpms a little too high). Also make sure the little spring wire holding the idle adjustment cable under the carb hasn't broken(common thing that happens on this carb and adjuster will just lay on starter area and vibrate and alter idling speed also) PLUS on this carb I would use a little anti seize on the adjuster threads. Water/dirt will corrode the threads. Just from what I've experienced. OPT
exmotocrosser
09-13-2019 06:12 AM
