2011 Sportsman 500 Trans Clunk
Normal as mentioned above to have gear lash on the 500,more noticeable on the larger machines. You have to figure from the motor to the clutches,then to the transmission,then to the drive shafts,there is going to be a little slack. If there wasn't, then something would probably break or wear out even faster! Enjoy your new ride! OPT
