Alternate Fluid Choices for '16 Sportsman 570
Ok, I know there are several experts on here and I want to ask about alternate fluid options for a '16 sportsman 570. I just did my first fluid change, at 23hrs and I used only Polaris fluids: PS-4 Oil, Demand Drive for front diff and AGL for transmission and they were costly. I don't want to sound cheap and I know you get what you pay for, but there are several cases that other fluids than manufacturer items are sometimes better. Could this be the case for my 570? If so, is there a list someone has generated to know what item is a perfect swap? Thanks.
JD
JD
Stay with Demand Drive Plus fluid for the awd system and AGL for the gear case if you can.Both are proven products over the years. There are other good gear case oils out there suitable for chain driven gear cases such as Amsoil if you wish you stray from the AGL.Not sure how much difference in price you'd be looking at. Engine oils,plus plenty of oil filters that can be cross referenced to the oem filters are out there. Can be your choice since there's no wet clutch to worry about if using oil with friction modifiers.
Only POPO fluid in the front diff. If you check around it isn't really much cheaper to use other fluids since it's all synthetic anyway. If you add the one-way valves to your diff and tranny vent lines and/or extend them up in to the headlight pod you won't have to change fluids that often. Did this on my RZR and after a year of abuse the tranny and rear diff fluid still looked new as the day I changed it. Motor oil and front diff will always need proper changing but it goes a long way being synthetic. Also want to use oem fluids if it's under warranty and keep receipts so you won't have any problems if there's a an issue with the machine.
chuck1177
03-06-2016 02:23 AM
