2015 Polaris Sportsman Touring XP drivetrain noise
#21
#22
After getting the service manual, I was able to remove both the primary and secondary clutches to access the internals of the transmission.
It ended up being one of the bearings and sproket came dislodged from where it sits inside the tramission casing causing the gearteeth to be misaligned. The gears were on the very edge of each other which is why under very light load the noise would not occur but under heavy accerlation it would slip.
Luckily the gears were not damaged, however, in the process of getting the primary clutch off and inexperience, I stripped the threads. Should I try a tap and die or just bite the bullet and replace the SUB ASM-PRIMARY SHAFT 50 TOOTH?
Also, is there any trick putting the primary and secondary clutches back on like there is taking them off?
#23
#24
Update, I was able to get inside the transmission but did not disassemble it completely. Originally I thought one of the gears was dislodged causing the gear teeth to be misaligned because that is certainly what it sounds like.
The original problem occurred after I ran over a log and had it lodged underneath the rear driveshaft. My logic was that the log somehow popped one of the gears out of where it sits inside the transmission casing.
Because I am certainly not an expert, I do not feel very confident completely disassembling the transmission much less being able to recognize problems besides obvious physical ones.
Any last advice before I throw in the towel and bring it to be serviced?
Thanks again for all the help!
#25
There's been two quotes I've heard over the years" One said "let your reach exceed your grasp",the other said "Know your limitations" I've kinda worked in between these two over the years. If in doubt,let someone that does this for a living look at it. Plus remember if you go too far and give up,some shops don't want to touch what you've worked on.
#26
#27
scottaruth
05-11-2020 06:58 PM
