02 700 sportsman speedo no go....
Old 11-14-2016, 04:50 PM
Dans_700sports's Avatar
Default 02 700 sportsman speedo no go....
So my speedo is dead dead... so naturally no awd.... if the speedo is totally shot can the little bypass repair still work? Where you ground the brown/white wire to get the switch to engage it or no?
Old 11-14-2016, 05:14 PM
Just jump the brown/white wire to the common ground wire(brown) in the speedo harness itself. No necessary normally to ground to the frame or another brown. This bypasses the speedo entirely. If you're the adventurous type there are a couple post on people tearing into speedos and repairing them. AWD and Speedometer don't work - Page 2 - ATVConnection.com ATV Enthusiast Community KA7OEI's blog: Repair of the speedometer on a Polaris Sportsman 500 4-wheeler Plus it might be worth a shot to talk to these folks that repair them.Speedometer Repair
Old 11-30-2016, 11:55 PM
thank you again with the good advice!
Old 12-03-2016, 11:28 PM
i unhooked it off the plug stuck an eyelet on it and attached it to my handle bar clamps seems to have worked.
Old 12-04-2016, 07:18 AM
As long as it works for you...
