Bayou 220 won't start
Old 12-02-2016, 02:21 PM
stevenlavergne202's Avatar
Default Bayou 220 won't start
I have a 1991 Bayou 220 that I can't start wit electric start. I can start it with the pull rope. I changed the battery, starter, solenoid switch and relay. neutral light won't come on but reverse will. any advise?
Old 12-03-2016, 02:35 AM
"neutral light won't come on" That will be your problem, not certain about the 220 but the 300 has a complex "lock out" system involving an extra solenoid. If it doesn't think it is in neutral, it won't send power to the starter solenoid. Sending it to a mechanic would have been cheaper than changing all those parts.
Old 12-05-2016, 09:11 AM
Thanks for your help! The local Kawasaki shop charges $90 an hour. I changed all these parts for $71. I know it is still not fixed but try to fix it myself. Thanks again!!
Old 12-06-2016, 10:04 AM
atv-wheeler's Avatar
Have you found out what's causing the issue?
Old 12-06-2016, 10:19 AM
I haven't had time to work on it yet.
Old 12-06-2016, 10:20 AM
I haven't had time to work on it yet. I will keep you updated.
Old 12-06-2016, 10:22 AM
I haven't had time to work on it.
