Sport Quads Discussions on sport quads.
Storm 650R
Old 08-31-2004, 03:54 PM
YamRap's Avatar
Default Storm 650R
What is a Storm 650R?
Old 08-31-2004, 04:30 PM
Yfz450VsBanshee's Avatar
Default Storm 650R
IMO its an expensive P.O.S with a $17,000 price tag
Old 08-31-2004, 06:47 PM
03250bayou's Avatar
Default Storm 650R
its a 650 2-stroke...it is 15k or 17k..whatever...way to expensive u could build something faster for much cheaper
Old 09-01-2004, 12:08 PM
YamRap's Avatar
Default Storm 650R
Who makes it?
Old 09-01-2004, 07:07 PM
maddog56's Avatar
Default Storm 650R
Storm I believe.
It has a lot of good aftermarket parts on it, it would be a close call on the price thing. Kind of like cdale, expensive, but its just because you are paying for all the good parts at once.
Old 09-01-2004, 07:49 PM
Default Storm 650R
On their site it says
Specifications
2004 Storm 650R
$17579 msrp*
Engine
Engine Type Race prepared 616cc liquid cooled, two stroke single with power valve
Bore and Stroke 95mm X 87mm
Compression Ratio 12.1:1
Carburetion Lectron 44mm
Ignition PVL
Starter Kick with Compression release system
Drive Train
Transmission Close ratio 5 Speed with Hydraulic Clutch System
Clutch 6 plate, Sintered Element in 6063-T6 Billet Basket
Driveline 520 X-Ring Sealed Chain
Chassis
Front Suspension Independent double wishbone, ELKA remote reservoir shocks with
adjustable compression, rebound, high & low speed dampening;
Quad rate springs with adjustable preload; 11.2 inches of travel
Rear Suspension Swing Arm, ELKA remote reservoir shock with adjustable compression,
rebound, high & low speed dampening; dual rate spring with adjustable
preload; 11.8 inches of travel
Front Brakes Brembo dual hydraulic with 175mm Galfer Wave Rotors
Rear Brake Brembo hydraulic with 220mm Galfer Wave Rotor
Front Tires AT22 x 7-10 Radial Mounted on Aluminum Rims
Rear Tires AT21 x 11- 8 Radial Mounted on Aluminum Rims
Rear Axle Adjustable width 4130 axle, Billet Aluminum Hubs
Dimensions
Length 73.00 inches
Width 49.75 inches
Height 43.10 inches
Wheelbase 52.25 inches
Seat Height 32.10 inches
Dry Weight 301 pounds
Wow only 301 pounds
Old 09-01-2004, 08:54 PM
DC504's Avatar
Default Storm 650R
very impressive machine but it is way overpriced i agree you could make something faster for less $$. still you gotta love a 650cc 2 stroke...and its 50 pounds lighter than a yfz 450!
Old 09-01-2004, 09:13 PM
CroBiker's Avatar
Default Storm 650R
if they made it a 650cc 4-stroke but used all the technology from the yfz450 motor, then maybe i'd be interested.
Old 09-01-2004, 10:18 PM
Default Storm 650R
Way to overpriced. I don't know what "Storm Atv" is smoking but who in their right mind would pay that much for a fourwheeler?
Old 09-02-2004, 12:01 AM
masterbalster200's Avatar
Default Storm 650R
Specifications
2004 Storm 650R
$17579 msrp*
Engine
Ignition PVL
Drive Train
Chassis
Dimensions
Length 73.00 inches
Width 49.75 inches
Height 43.10 inches
Wow only 301 pounds
whats the name of the site
Quick Reply: Storm 650R
