Help with a Suzuki LT 160
Old 05-29-2011, 09:37 PM
PTG's Avatar
PTG
PTG is offline
Default Help with a Suzuki LT 160
I have a Suziki LT 160 with broken choke and reverse gear cables. I was wondering if you must use special Suzuki cables or if you could use a different type? Thank you for your help.
PTG
Old 05-29-2011, 10:03 PM
dakbee's Avatar
you can find choke cable son ebay for around $20....the reverse cable looks as if its only a suzuki item, but can be found on ebay also around $50...might try a local nonbrand cycle shop
Old 05-30-2011, 11:34 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
tried doing exactly that with non-suzuki parts, and it was a waste of time and money for me (and I'm mechanically inclined) It never worked out as well as it did with the stock setup, so I spent the extra coin, got the right parts, and haven't had a problem since, which is my recommendation to you
VABrute
01-06-2016 07:39 PM
clscott84
09-21-2015 10:16 AM
merryman
09-19-2015 03:15 AM
jsmit116
09-18-2015 10:34 PM
09-01-2015 11:59 PM
Quick Reply: Help with a Suzuki LT 160
