Valve specs LT-4WD
Old 08-12-2011, 06:19 PM
mgmcomm's Avatar
Default Valve specs LT-4WD
Can anyone tell me the exact size of the intake valve on a 1987 Suzuki LT-4WD. It should be the same as the LT-F250 as well as many others. As far as I can tell the same valve was used for nearly 15 years on various models. I need to figure out if my head is bad or if its just the valve. I really do not have the money to waste on guessing and I happen to have a micrometer at my disposal. Both the head and the valve look to be perfect but when I put the valve cover on then the valve is unable to fully seal due even though the adjustment screw is all the way out. I should have 15mm gap on the intake I believe but with full loosing of the valve adjustment its still holding the valve open.
Old 08-15-2011, 07:33 PM
diamonbird's Avatar
I believe the intake should be set at .007mm and the exhaust at .013mm.
Scooter's Shop
23
10-22-2015 07:04 PM
wrencher82
09-30-2015 04:27 AM
wrencher82
09-28-2015 10:02 PM
2many2ride
09-27-2015 04:35 AM
maveikfe
1) Engine problems..
09-24-2015 10:36 PM
Quick Reply: Valve specs LT-4WD
