quadrunner 160 carburetor adjusting...
my nephew just decided to try & get his dad's old quadrunner 160 running after it's been sitting in a barn for i would say at least 5 years. after a new battery it actually cranked right up but has very little power. if you let off the gas it dies. if you press the gas more than a little it dies. drained the gas & put fresh in it. took the bowl & float off & cleaned them out. there was a good bit of trash in the bowl. now after putting it back on the thing won't crank at all. it seems like it's a fuel problem but i'm no mechanic & don't really know where to go from here. there are 2 screws on the carb with flat head slots. one is knurled & i'm guessing it's the idle adjustment but the other brass colored one i don't know. if some one could point me to some kind of how to i'd appreciate it.
After 5 years, the inside of that carb is probably pretty green and gunky, gonna need a complete tear down, I suggest finding a shop with an ultrasonic cleaning tank, that will get all the caked on crud in all the passages broke loose. More than likely, the pilot jet is plugged up, thats why it dies when you let off the gas. I let my 300ex sit in storage for 2 years, and that carb was a mess, took a lot of port blasting and scrubbing to clean it up, but it runs like a charm now, sold it to a co worker,and his son loves it to death. Time for you to crack open that carb and assess the damage.....good luck.
yeah, the inside of the bowl & float were covered in crap. i can imagine what the jets look like. on a side note, i've got another 4 wheeler that's having float needle stick. it's sticking closed. doesn't do it all the time but normally when you ride it it's just a matter of time. i'm guessing some carb cleaner & a really small wire brush will clear it right up?
If the needle is all metal, I would spray some carb cleaner on some Scotchbrite pad, and spin the needle tip on that, that will shine it right up. For the seat, try a Q-tip soaked in carb cleaner, stuff it in the needle port and spin it, if you can see in and it isnt clean and shiny, try a dab of rubbing compound on a Q-tip to spin in there and polish it up, then blast it out with carb cleaner, and that should cure the sticking. If your needle is rubber tipped, just soak a rag with carb cleaner and spin the tip in it, don't want to rough up or damage the tip if it's not metal.
09-01-2015 11:59 PM
160, accessories, adjusting, adjustment, atv, carb, carburator, carburetor, engine, idle, needle, quadrunner, suziki, suzuki, tuning
