91 LT4 250 running rich/carb backfire.. want to replace carb
Old 04-30-2015, 05:57 PM
zmame's Avatar
Default 91 LT4 250 running rich/carb backfire.. want to replace carb
Hey everyone,
I've been having issues with my 1991 250 lt4 quad runner. When you start it you can smell that its running rich i have the idle screw all the way in and i have to hold the throttle for it to idle. While idling it backfires out of carb and dies.. you can smell real rich out the exhaust.
I dumped the oil had oil/fuel mix
took apart the carb and noticed float needle had some wear so replaced seat and needle, adjusted float.. inspected & tested float for cracks put back together and still dose the same thing.
I tried finding a replacement carb on ebay there are currently non available.
Is there a different slide style carb that i can buy for this bike.. im not too keen on the CV style carb that is currently on it.
I really want to get this working before may long weekend.. getting tired of taking the carb apart trying to figure this out.
Thank you in advance,
Nick
Old 04-30-2015, 06:11 PM
Just guessing if it's the old round type slide,could be a VM30 to 34 Mikuni type carb. Most on ebay have the manual choke though,couple have the cable style.http://www.ebay.com/itm/Mikuni-Geniune-VM-30mm-30-mm-Round-Slide-Carb-Carburetor-VM30-83-/201340967487?hash=item2ee0db5a3f&vxp=mtr http://www.ebay.com/itm/Mikuni-Geniune-VM-34mm-34-mm-Round-Slide-Carb-Carburetor-VM34-389-/400904287015?hash=item5d57c1f327&vxp=mtr
Old 04-30-2015, 06:29 PM
zmame's Avatar
The one thats on it now is a CV style carb i want to convert it to slide style.
Not sure on the dimension since the bike is at work ill measure it in the morning
Old 04-30-2015, 06:40 PM
Then you probably have a BST 34 Mikuni as Suzuki,Yamaha,Polaris almost all used Mikunis except Honda that used the Keihin. Fittings may be different.http://www.ebay.com/itm/POLARIS-ATV-CARBURATOR-FITS-THE-4-STROKE-ATVs-MIKUNI-CARB-MAGNUM-SPORTSMAN-/391114199810?hash=item5b10391302&vxp=mtr
Old 04-30-2015, 06:47 PM
zmame's Avatar
Awesome that looks like my carb right there.. good price ill just buy it lol
Suzuki they wanted like $700
Thanks alot your a life saver
Old 05-01-2015, 02:17 AM
Hope the carb works out for you.Check the jetting on the new one,probably have to use your old carb jets.
wannabe32
07-07-2015 11:30 AM
robj
06-15-2015 08:45 PM
DOAinNY
06-11-2015 10:34 PM
generalpops
06-05-2015 08:23 PM
generalpops
06-03-2015 08:25 PM
Quick Reply: 91 LT4 250 running rich/carb backfire.. want to replace carb
