LT250S/230S clutch arm install
Old 03-21-2016, 07:38 AM
Sebastian24's Avatar
Default LT250S/230S clutch arm install
Hey guys, so I got the engine together, and put the clutch cover back on... now I cannot put the clutch shaft in... Is there a trick to this, or do I have to take the cover back off? The Clymer manual doesn't specify how it should go in it seems...
Thank you,
Sebastian
Old 03-21-2016, 02:21 PM
bump
Old 03-22-2016, 07:35 AM
bump. I'll have some time to work on it tonight, any help would be greatly appreciated
Old 03-22-2016, 08:03 AM
Seems to me the clutch arm should have been mounted to the cover first. Then it would center it self on the "flat' area when you installed the cover. Only way I'd say you can install it after the cover is already on is to push it down,turn it to where it could get by the clutch pusher. You may not be able to install it this way without interference.
Old 03-22-2016, 01:14 PM
Yeah that's what I was thinking as well, I was hoping there was a trick to it or something...
When I took it out, the arm came off before the cover was taken off, which seemed weird to me as well.
I guess back to opening this thing up haha
darrm1
03-24-2016 11:38 AM
user493
03-21-2016 04:46 PM
Snow Rider
03-21-2016 03:05 AM
Sebastian24
03-17-2016 03:14 PM
garrison1080
03-15-2016 05:02 PM
Quick Reply: LT250S/230S clutch arm install
