Polaris 700 Sportsman
Sounds like a common problem that many efi machines have had on not being able to idle or has an erratic idle,back firing,etc are some of the symptoms of a faulty tbap connector or wiring harness.Plus a lot of times codes may nor be shown or if they do codes 41,45 or 46 may show up. Like the manuals say 80% of efi problems are wiring or connector related,not sensor related problems. Read this "sticky" post that kind of sums up what many have done and one member has come up with better harness repair kits than the ones I had to install that kept failing because of thin wires and cheap connectors. https://atvconnection.com/forums/pol...ap-wiring.html Here's the site for better repair kits.Only The Best Plus here's the pic of the tbap kit that people most often replaced on the 700/800 models.
Thank you that helps a lot
Ckieffer29
04-01-2016 04:49 PM
Zorro
01-07-2001 05:03 PM
ronhonda
07-04-2000 12:27 AM
