Brake light will not turn off on warrior
Old 06-14-2020, 01:19 PM
Doom's Avatar
Default Brake light will not turn off on warrior
Hello my brake light will not turn off on my 2002 warrior ...it does not change shades of red when the brake pedal is pressed like it used too ...I changed The lights a couple weeks back to OEM. But no one noticed the brake light is on till recently ,don’t know if it’s a coincidence thanks
Old 06-15-2020, 02:21 AM
Don't know the Warrior, but most quads have a brake light switch on each brake lever, and one of them is often stuck in the on position, making the brake light on all the time the ignition is on. Can be a lever not quite going back to it's stop, or a broken switch. You need to find which lever/switch it is, and fix it.
Bayou300ex
06-02-2014 07:46 AM
JaCkaL829
08-10-2009 08:22 AM
gruss
02-10-2008 01:54 PM
ZoomZoom14
04-15-2005 06:43 PM
fpratt
06-07-2004 10:15 PM
Quick Reply: Brake light will not turn off on warrior
