1996 Warrior
Old 01-30-2008, 11:00 PM
lowgmc's Avatar
Default 1996 Warrior
I thought that the 96 Warrior was supposed to be a 6-speed tranny????????
I'm only shifting through 5 gears.
Old 01-30-2008, 11:25 PM
Raptor450's Avatar
It is a 6 speed. Evidently you have some tranny or shift fork problems.
Old 01-31-2008, 12:09 AM
cynick's Avatar
They only have 5 forward gears, 1 down 4 up. But they do have a reverse gear so technically they do have 6 speeds.[img]i/expressions/face-icon-small-wink.gif[/img]
Old 01-31-2008, 02:49 AM
TomM's Avatar
Pretty sure they have 6 gears. My 87 definitely does. 1 down 5 up. Maybe your not using the 1 down. Mine makes so much torque I rarely use first gear. Sometimes simple things will cause a shifting problem. My freind told me first gear was "blown out" on his ATC250R. I took a look and found right off the shifter had slipped and was hitting the frame so it couldnt go far enough down to get in first gear.
Old 01-31-2008, 09:31 AM
54warrior's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: cynick
They only have 5 forward gears, 1 down 4 up. But they do have a reverse gear so technically they do have 6 speeds.[IMG][/IMG]</end quote></div>
What have you been smokin??
All Warriors and Raptor 350's have 6 speed transmissions. I down, EDIT: FIVE up. Nothing's changed since '87.
Old 01-31-2008, 11:37 AM
TLC's Avatar
TLC
TLC is offline
<div class="FTQUOTE"><begin quote>Originally posted by: 54warrior
All Warriors and Raptor 350's have 6 speed transmissions. I down, 4 up. Nothing's changed since '87.</end quote></div>
Not sure but does that not add up to 5?
Old 01-31-2008, 01:22 PM
Raptor450's Avatar
They definately have 6 gears. I'd bet my left nut they do.
Old 01-31-2008, 01:43 PM
racerex1's Avatar
The funny thing is, I never really took note.....as I go through the imaginary gears with my left foot, with a little sound effects tossed in as I sit at my deck at work.......I want to say 1 down, 4 up plus reverse = 6. Now the kid that has the cube outside of my office is looking at me wondering what the heck is that guy doing in there [img]i/expressions/face-icon-small-smile.gif[/img]
Old 01-31-2008, 07:19 PM
beefy46172's Avatar
Loves To Ride!
I'll bet both nuts and my Warrior itself all Warriors have a 6 speed (1 down, 5 up). If you don't have sixth you've got a problem.
Old 01-31-2008, 07:50 PM
Raptor450's Avatar
If you add reverse that would be a 7 speed!
Quick Reply: 1996 Warrior
