carb 101
carb 101
all this depends on how your bike is running. there are 5 positions on the needle. top being the leanest and bottom being the richest. i have my needle clip in the middle position, which is ideal. if you move the clip up you lower the needle making it leaner. if you move the clip down you raise the needle making it run richer.
for the air/fuel screw turning it in leans it and turning it out richens it.
carb 101
you may have to adjust your air/fuel screw a little. i also have a 150 main and a k&n on my warrior. and i have a WB e-series slip-on. my air/fuel screw right now is at 2 turns out. but it's running a little on the rich side so i still have some adjusting to do. other than that it starts right up and idels fine and the thottle response is great. so your settings should probably be close to mine. unless your exhaust calls for something else.
