oil cooler for '00 warrior
fourstroketech has an oil cooler kit that taps into the clutch cover, then routes the cooled oil to the cam,this is supposed to keep the cam and bearings supplied with cooler oil, the top of the motor will run hotter than the bottom. For a quick and easy add on, you can find an oil filter cover from a Big Bear or Wolverine, they com with oil line fittings on them, then pick up the oil cooler and lines from the BB or Wolvy, then you can attach it up front, and you are all set. You can also go to an auto parts store and get an oil cooler and fab up your own lines.
