blasty; fuel out pipe
Ok,
Kicked on the 01 beater blaster, fuel pours out the pipe, i took off the bolt to i guess the clutch/gear oil, a lot of fuel.. oil... poured out.
So it seems as if some needle is stuck or something... or maybe i just need a carb clean.. So, i talked to a mechanic, said something about if when you rev it, something about if it revs down, and something about if it revs down like : "WAH WAH- WAH -WAH-WAH-WAH-WAH-WAH".. and something about some seal that sounds serious...
So.... any ideas? I really hate to take it to someone, have them poke on it for an hour at $60+..
It's probably your float valve in the carb is stuck which keeps letting fuel into the carb from the gas tank. It's supposed to have a drain tube out of the carb to help prevent this from happening (fuel just dumps out on the ground instead) but that tube passage may be stopped up too. I would start by cleaning the carb, making sure to pay special attention to the float valve.
Oh yeah and your crank seals are probably leaking because your fuel should never mix internally with the oil
All you have to do is just loosen the carb enuff to turn it sideways so you can get the 4 screws off the bottom that hold the bowl on. Then you have 2 brass jets (main & pilot) then the float assembly(floats look like 2 pontoons). The suspect valve is the brass piece attached to the floats that moves up and down when the floats move up and down. Just be careful with the floats they have small pieces for the hinge that can be lost very easily. Dont forget to clean the bowl drain. No need to set anything on fire lol!
Cleaned the carb, used lots of carb cleaner, finally got the TORS off by simply twisting it off Now have fuel pouring out the carb, so i guess it's still flooding it, but it will run. Bad crankseal i'm pretty sure and somethings sticking in the carb.
Thanks fellas, should have her fixed.... sometime
