1998 Big Bear 350 4x4 - Oil drain plug stuck
Old 03-31-2014, 10:44 AM
foolhardy's Avatar
Default 1998 Big Bear 350 4x4 - Oil drain plug stuck
I have a '98 Big Bear and I'm attempting to change the oil for the first time. Unfortunately, I've found that I'm unable to get the drain plug out. I've tried, with a 19mm socket, to the point that I've begun to round the bolt head. SO, I stopped and will resume next weekend with more intel, hopefully.
I've been reading around and I've found two suggestions so far:
1. Apply heat for a couple of minutes - I have a propane torch that I could use to apply heat to the plug. Is this a good suggestion or bad?
2. Tap around the edges of the plug with a hammer to try and jar loose whatever is stuck.
I would appreciate any input on these two possible methods of attack as well as different suggestions entirely.
Old 03-31-2014, 11:00 AM
Just go to Sears,Harbor Freight and get a set of these sockets.You don't have to buy expensive Snap on tools for this. I got a cheap set at Sears on sale for about 15 bucks few year back and worth the money to have in the tool box..
Old 03-31-2014, 11:26 AM
foolhardy's Avatar
Old,
I just ordered a set. Thanks a lot for your help. Do you know, will these further damage the plug or will be able to reuse it with the same sockets in the future?
Old 03-31-2014, 10:43 PM
Won't further damage an already damage bolt,just get it out for you. Best to have a new drain bolt and make sure you over tighten the new one.
Old 04-01-2014, 07:31 AM
foolhardy's Avatar
Old,
Thank you for your input. Could you please elaborate on how much to "over tighten"?
Old 04-01-2014, 01:41 PM
Service manuals tell you how much torque on a drain bolt,but normally 12-15 foot pounds on most machines.
Old 04-01-2014, 01:47 PM
foolhardy's Avatar
Thanks a lot, I'll keep that in mind.
skinnyr6
08-25-2023 02:18 AM
Sjrpp
06-02-2019 07:25 AM
honda71
07-12-2015 05:56 AM
honda71
07-08-2015 02:13 AM
Shifts
07-03-2015 07:59 AM
Quick Reply: 1998 Big Bear 350 4x4 - Oil drain plug stuck
